3 members (55shaker, Otto Skorzeny, GMCJammer51), 97 guests, and 0 robots.
Topics128,050
Posts1,055,646
#1523477 10/25/2023 8:53 PM
Hi, A friend gave me this motor said it was a 400. Code on the pad is TO325CTD I could not find any info on it any help would be great. Thanks Steve
7
7 Offline
You should also find a casting number on the block, rear left just above where the bell housing mounts, how many freeze plugs are in the side of the block?
I will look tomorrow when I get to the shop Thank you
Insomniac
Insomniac
Decode it here: https://nastyz28.com/chevy-engine-code-stampings.php
You have a 400 originally installed in a Caprice with automatic transmission and 4 bbl carb. 175 HP. Built March 25 in the Tonawanda plant.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
A 400 will have a very large harmonic balancer, with a weight cast into one area- - - -those engines need to be externally balanced. Ditto for a flywheel or an automatic trans flex plate- - - -there's a balance weight on it if it's on a 400. The "T" prefix on the engine number generally means it's s truck engine- - - -probably with 4 bolt bearing caps on the number 2,3, and 4 main bearing webs.
Thank you for the info I will pull the pan and check what Hotrod said and get more numbers from the block. Thanks again Steve
5 Online: Content
CTD could either a 1974 400 or a 1978 305. Scroll down the chart till you see CTD.
http://www.1968ss.com/sbcsuffix.asp
Also run your hand down the side of the block. 305 will be flat. A 400 will have slightly protruding lumps because of the larger bores. 400 will have a notch cut out of the harmonic balancer, because it's externally balanced.
Brian
1955.2 3100 Truck
5 Online: Content
Hey Steve, did you ever figure what you had?
Brian
1955.2 3100 Truck
Been away for a while yes I did thank you.
