10 members (Otto Skorzeny, 49fastback, jmoore, HandyAndy, Rusty Heaps, Joe H, GMCJammer51, 66flea, 68ironhead, Cosmo), 94 guests, and 2 robots.
Topics128,035
Posts1,055,567
#1516505 09/08/2023 8:37 PM
I have to replace the output shaft bearing in '41 1/2 ton PU (AK) 3 speed transmission and my mechanic says that we will need a special flat wrench to remove the Bearing Retaining Nut. According to my shop manual it says we need a J-112 wrench.
I have looked and can't find one on the web. Where or what should I be looking for?
ronsway #1516512 09/08/2023 9:34 PM
7
7 Offline
you may have to fabricate one yourself.
ronsway #1516516 09/08/2023 10:12 PM
O Online: Content
What size wrench?
Many bicycle repair wrenches are very thin - like 1/8" or less.
1950 Chevrolet 3100 (Ol' Roy)
ronsway #1516531 09/09/2023 12:29 AM
Ah yes, the famous GM J- tools. A lot of the factory manuals have pictures of the specialty J- tools. See if you can locate a factory manual for your year truck. You can then use that picture to fabricate your own tool. Make sure you get back to us when you get this done with pictures of your tool. Make sure that you stamp "J-112" on it. smile
ronsway #1516551 09/09/2023 10:06 AM
Haven't seen a J-112 but a J-933 is the correct wrench for the post-war 3sp clutch (input) shaft. I just tried it on a 1940 trans and the fit is the same. Look at the pics. 1/8" thick and 1-5/8" jaws. I think the bend in the handle is probably irrelevant, but it does make for better balance. May be why you can't find a 112, it was probably superceded by the 933.
Need a press. It's a press fit.
Make sure you re-stake the nut when you put it back on.
Make sure the snap ring fits the recess... may have to use the old snap ring. I did.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
ronsway #1516554 09/09/2023 11:27 AM
O Online: Content
How did you clean up those gears, Jethro?
ronsway #1516557 09/09/2023 12:18 PM
That gear is a worn out one I use as a tool to line-up the clutch installation and the bearing race welded to the other end is used as a driver for installing the rear axle seals.
I put a new clutch shaft in my 3sp. It was jumping out of 3rd.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
ronsway #1516587 09/09/2023 4:01 PM
Find a 1 1/2" open end wrench at a pawn shop or a flea market, and spend some quality time with an angle grinder to thin it down, then adjust the opening to fit the flats on the nut.
ronsway #1516606 09/09/2023 4:52 PM
Jerry, just getting some 1/8" flat stock would result in a smaller pile of steel dust from the grinder. I've made a couple wrenches from flat stock, although mine was 1/4" thick for a fan clutch.
ronsway #1516611 09/09/2023 4:59 PM
O Online: Content
Buy a wrench that's already 1/8" thick, like the one pictured, and grind the jaws to the desired size.
ronsway #1516703 09/10/2023 2:53 AM
Ron,
I will add my $.02 worth in here to offer another "alternative" tool.
First, a check of various Chevrolet Master Parts and Accessories Catalogs, starting with the 1929-41 Book, indicates that the "bearing retaining nut with oil slinger" is GM# 591150.
Second, a check of GM# 591150 through GMPartswiki shows that the same part number was used in all the early (1937-50) standard 3-speeds, the SM318 3-speeds, as well as later Muncie (1963-74) 4-speeds. Same part number across all these transmissions, checked through the various Parts Books through the 1979 edition.
That being said, it should be safe to assume that a more recent "wrench" for removing said retaining nut w/slinger for the Muncie's should take the place of the original J-112 removal tool.
Jethro's "J-933" wrench would work, if you could find one. Here is a link (not mine) to an Inexpensive wrench designed to do the job for Muncie's and should work just fine for your 3-speed. No fabrication or modification involved and readily available.
Let us know what you figure out and what may or may not have worked. smile
Dan
~ Dan
1951 Chevy 3 window 3100
ronsway #1524247 11/01/2023 1:59 AM
62401
So is this wrench I have, from an auction "treasure box" lot that I've never identified, one of these J tools?
The jaws are 1 11/16 at the opening and 1 9/16 at the bottom of the straight parts. The small end appears to be 9/16.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
ronsway #1524248 11/01/2023 2:13 AM
John, yours may be a knock-off of a GM special tool. If it was genuine, it would have markings like the ones on Jethro's above.
ronsway #1524250 11/01/2023 2:40 AM
62401
Kevin... could very well be -- no markings on it. And it doesn't look all that old. I had thought it was a tool for a router chuck or something.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
ronsway #1524255 11/01/2023 3:19 AM
Thin wrenches. Like Bonney wrenches.
ronsway #1524264 11/01/2023 12:00 PM
AD Addict & Tinkerer
Looks just like a wrench that came with a bicycle. The large side was for adjusting/removing the bearings on the crank.
I made the Input Shaft Wrench from 1/8” flat stock. I welded two pieces together as I didn’t have any plate wide enough. Crude but effective.
SM-318 Input Shaft Retaining Nut Tool
Phil
Project Journals
Stovebolt Gallery Forum
Moderated by  MNSmith
