8 members (DadsFirstPickup, GradyB, GRNHydra, Jay R, TUTS 59, JW51, Ponchogl, Leo), 82 guests, and 0 robots.
Topics128,080
Posts1,055,944
Members48,430
#152415 05/03/2007 7:12 PM
Hello folks,
I am getting ready to slide my engine/tranny in and am at my last item. A clutch kit. My clutch is a 11". The engine is a 261. The good folks @ Napa say it should have a 12". Anybody out there seen anything like this before. I would imagine there is a model out there that used a 11". Maybe not a C-60. Something else? As usual thanks for all replys from the brotherhood!
240,000 worker bees!
1960 Two ton Chevy
#152416 05/03/2007 7:21 PM
I would go with the 12 inch for more surface area. Make sure your throw out bearing matches your presure plate.You don't say how hard you are going to work this truck,but larger is good insurance.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#152417 05/03/2007 7:51 PM
The flywheel I had resurfaced and want to use it it accomdates a 11" disk and pressure plate. I wonder if the flywheel was changed through the sands of time. To what, I don't know. I don't know what else used a 11". I'm sure someone out there does? As far as work I plan on hauling saw logs with it in northern Mn.
1960 Two ton Chevy
#152418 05/03/2007 8:42 PM
3B Offline
Hy Beewrangler, how many bolts hold your pressure plate to the flywheel?
#152419 05/03/2007 9:45 PM
Riding in the Passing Lane
The 11 &12" fit the same flywheel. I like the 11" better unless you are going to handle some heavy loads or you or another driver are hard on clutches. The smaller one is softer & is easier on the trans. syncros.
1972 Chevy c10 Cheyenne Super
#152420 05/03/2007 9:58 PM
There are six bolts that hold the pressure plate on. I was not aware you could use an 11" or 12" clutch set on the same flywheel.
1960 Two ton Chevy
#152421 05/04/2007 12:38 AM
My 52 chevy with a 55 235 has an 11" clutch with a 9 bolt pressure plate. The clutch and flywheel could be from the original 52 engine?
1952 Chevrolet 3800 pickup
---All pictures---
#152422 05/04/2007 10:16 AM
The earlier 270 used a 11.5" plate but with a 9 bolt pressure-plate, if it's any help.
The later 270's had a different flywheel with 6 bolts attaching it to the crankshaft (instead of the earlier 4 bolt) - but I don't know how many p/plate bolts these had.
Is this for your '46 or '60 truck?
#152423 05/04/2007 4:06 PM
3B Offline
Hy Beewrangler, a pressure plate with six retaining bolts appears to be 54 and newer, the earlier ones had nine retaining bolts. So your looking for a clutch from a 54 or newer engine, according to my clutch book in 57 all 3400, 3500, 3600, and 4000 series with a six cylinder engine used an 11" clutch, hope that helps.
#152424 05/04/2007 7:47 PM
Thanks for all the replys. Where else can you have a conversation about a truck thats 40+ years old with guys from Mn, B.C.,New Zealand, Va, KS and NY.
Thanks!
1960 Two ton Chevy
#152425 05/06/2007 10:48 PM
I have a a NOS 11" diaphram clutch pressure plate assebly and a NOS 11" disc, I even have a NOS 6 cyl.flywheel to match it. E-mail me if I can help. [email protected]
#152426 05/06/2007 10:50 PM
The 9 bolt clutch that was used in 1938-53 trucks was a 10 3/4" disc.
