3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#1523987 10/29/2023 11:43 PM
Hi again. Seems like everything I touch needs work.
My brake pedal doesn’t come all the way up after use. I have a new return spring but haven’t figured out how to get it on. Need to know the secret of getting the old one out first.
I’ve tried using channel locks and made up hooks from a coat hanger but can’t get the spring to clear the wire hook on the end. I’m really worried about getting the new one on if it is stronger than the old one.
Sure could use some sage advice.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1523988 10/29/2023 11:47 PM
Have you tried a block and tackle? or a come-along? wink
I don't recall having issues getting mine off. I assume you're talking about the one that goes to the bracket on the frame just below the steering column.
T-Doug #1523994 10/30/2023 12:10 AM
That’s the one Kevin. Can’t seem to get a good grip on it to undo it.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1523996 10/30/2023 12:54 AM
This is what I used...worked great!
GEARWRENCH 3-1/8" Mini Full Hook - 84004H https://a.co/d/hWoit4x
1949 3100
I like that tricordati. If I can’t fab something I’ll get one
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
I use vice grips, and muster up the strength of ten Grinches plus one to get it on. You may need more or less Grinches than I do, but it does take several.
T-Doug #1529234 12/11/2023 11:28 PM
I was looking for an older post and ran across yours. I assume you got it fixed? My 2 cents worth. My pedal would stick about an inch before it was up completely. With the motor out I decided to deal with it. I bought new springs for the clutch & brake. The brake pedal shaft was sticking (wedging) in the hole. When I loosened the large bolt the pedal loosened up. I readjusted it & tightened it in position & all is fine. By the way my springs are not hard to stretch .
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
Peddle looks like bushings worn to be making its own hole through the cab.Could also be cab mounts .Mine would rub until I fixed bushings.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
