If the Chevy engine is still in the Chevy truck measure the distance from the forward most point on the Chevy engine (probably the leading edge of the fan blades or the fan mounting bolts) to the radiator. That dimension is an inch and a half longer on the GMC. Don't forget to have enough space to get the fan belt through the gap when you are changing it.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
