3 members (RonG, Forty9, Jon G),
126
Mod | | | Forums66 Topics128,163 Posts1,056,964 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I am having a day... Looking online, I cannot seem to find the rubber seal for the rear-most side window (fixed) on my '57 Suburban. Sure, I see Steele rubber has them, but I really cannot afford Steele's prices... Any other source? Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Sep 2009 Posts: 5,983 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,983 | wave1957, Perhaps this on-topic Suburban Rear Window Tech Tip by our own Ken "bartamos" might provide some useful insight on your rubber seal search??? His Tech Tip also refers to this original conversation on the topic. In there he indicates the 1960-66 Chevy and GMC Suburban fixed rear window gasket is the same as for your 1957 Suburban. A whole bunch cheaper than the Steele product and maybe helpful for your need. I would note though that the reputation for "Steele" products is pretty much at the top of most everyone's chart for quality and proper design/fit. Many folks will tell you, yup it may be the most expensive, but also the least hassle and best product in the long run. Your choice on which way you want to go. Let us know how your glass project comes along.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Yes, I have read the tech tip you mention, and I saw that Bartamos mentions that he "believes" that the '60-'66 is the same as the '55-'59: I would like to be sure before ordering, I guess I could check on the Steele website, comparing part numbers... I know that Steele has a very good reputation, but my truck is rather the "patina", daily driver-style, half of it in primer for the last 10 years with rust holes, so I do not want nor need the Steele quality! You will indeed hear from me again about my side windows in the next few months, as I will restore a sliding window and turn a fixed window into a siding window, and I will probably have questions... Thanks
EDIT: it is interesting that on the Steele catalogue, they have the rear quarter window weatherstrip for '55-'59, but not for '60-'66; it seems to imply that they are not the same... Maybe someone can confirm either way?
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I am still searching, following your ideas, Gdads51. Steele does have the rear quarter window weatherstrip for 1966 (not '60 or '61), but it has molded, square corners, so a no go as is for me. On the other hand, they show the cross-section, and it is indeed the same as the '55-'59. So, I should be able to buy the part you linked for me, on Classic Parts. But then, if it is the same cross-section (as per Steele), why isn't Classic Parts showing it as a '55-'59 too? Thanks for helping think and make some progress in my search!
| | | | | Joined: Oct 2021 Posts: 6,936 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,936 | High quality is long remembered after the higher cost is forgotten.
1950 Chevrolet 3100 (Ol' Roy)
