1 members (klhansen),
147
0
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | I have a 1941 Chevy with a rebuilt 216 that I never drive because it stinks, like nearly all old cars. I’m sure I’m more susceptible to the fumes than most people. Therefore, I’d like to destinkify it. I’ve thought of a few options and would appreciate feedback on the likelihood of success of each option:
1. Install PCV, TBI fuel injection, and a catalytic converter on the 216, using a 4 barrel style intake. Thoughts on whether typical aftermarket EFI systems work well enough to keep a cat alive and working efficiently? 2. Rebuild the 261 I have sitting in my garage with as much compression as practicable and put in a propane carburetor and install a propane tank under bed. This would be more cost/work but would be lower tech so maybe more likely to work? 3. Buy a trailblazer and swap the vortec 4200 and auto transmission over, change to open driveline. A ton of work but should result in a totally modern drivetrain. | | | | | Joined: Oct 2021 Posts: 6,934 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,934 | You can put a Holly Sniper on the engine but I wouldn't use a catalytic converter. You can convert the 216 to propane so no need to worry about the 261.
Personally, the smells of old cars - uncatalyzed exhaust, gasoline, and hot oil - are one of the things I like best about them.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't know what smell you are talking about but you are suggesting some weird remedies. Assume you mean exhaust: The fix for that is fix the exhaust. Pipes, connections, rust outs, gaskets, tailpipe location, manifiold leaks. Then seal the firewall. Seal air vents, heater vents.
Motor may have excessive blowby. That would be a separate issue.
Or you may be taking about gas fumes. Leaking carb, lines, gas tank or cap vent issue, etc.
Also, some of us like a little bit of those smells.
You must identify what you smell and where it's coming from to get meaningful help. None of which will be too close to your suggestions. Many folks here have probably had these issues with Pre AD, AD and beyond.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | My 216 used to stink enough that my wife could smell it on me (clothes, hair, facial hair) if had driven the truck earlier in the day. When I swapped from the Rochester B to a Carter YF and got the YF set up with the proper needle & seat valve, it stopped smelling bad and I don't smell like fuel-rich exhaust like I used to. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | The fumes are unburned hydrocarbons. The easiset solution is to make sure your engine is in good condition and tuned up properly. Bad rings, valve stem seals, etc will leak oil into the cylinder where it will burn and smell.
Tuning it to run rich will give you more power (up to a point), but also result in unburned fuel and fumes.
Mis-adjusted timing will also result in unburned fuel and contribute to the smell.
If you have not given the truck a good tune-up and adjustment, I would recommend starting there. Some kind of a fuel injection system will help if tuned close to stochiometric (14.7:1), but the overall condition of the engine will have a larger impact.
I would disagree with Otto on the catalytic converter. Trying to run one with your old carb is highly unlikely to work long term. Putting one on with a fuel injection system that is more consistent in its fueling should be fine. Modern cats don't cause the performance hit that they did 40+ years ago.
I personally like the aftermarket fuel injection systems (and you will get mixed opinions around here), but they are not a panacea for all that ails your drivetrain.
I will warn you that propane conversions are a strict No around here. You just don't want to go there.
As far as a body swap, that is a lot of effort but you gain modern drivetrain and suspension. Depending on your long term goals and what you are willing to invest, it can give you a really nice rig. But again, it is a lot of time and money if your real goal is to just reduce fumes. | | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 |
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | NAH! Convert it to diesel and use fryer oil, then it'll smell like french fries.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | NAH! Convert it to diesel and use fryer oil, then it'll smell like french fries.  Best plan! I vote for this. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I know what you are talking about. There is a unique interior smell to cars from the 60's and 70's. That said, if the smell of oil and exhaust is getting to you the propane idea gets rid of the gas smell. I made a long extension to my draft tube on my cummins and into a peanut butter container. No more oil fumes into the cab. This might work for you as well. | | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 |
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | If I remember correctly, crunchy. I empty it every fall. | | | | | Joined: Nov 2020 Posts: 788 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 788 | Friends don’t let friends do electric conversions. How bad must the op truck smell that he doesn’t drive it? He did say it smells “like almost all old cars” …. Most of us like the old car smell , that’s part of the experience. Answers to questions asked by Bartamos are needed. If the exhaust or fuel smell is abnormally bad then something needs to be fixed. On the other hand, if the truck does smell normal for it’s vintage and type , maybe it’s a matter of incompatibility.
| | | | | Joined: Nov 1995 Posts: 5,733 24601 | | 24601 Joined: Nov 1995 Posts: 5,733 | My 216 used to stink enough that my wife could smell it on me (clothes, hair, facial hair) if had driven the truck earlier in the day. When I swapped from the Rochester B to a Carter YF and got the YF set up with the proper needle & seat valve, it stopped smelling bad and I don't smell like fuel-rich exhaust like I used to. EBS -- while it may be too late for you, it might not be too late for others who may want to address the reasons (fixable!) why their B-series Rochester carb runs rich. A new Tech Tip is about to be unveiled in the engine forum, authored by our own JonG! Stay tuned!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
