4 members (walter74, Otto Skorzeny, Ponchogl, Cosmo), 103 guests, and 1 robot.
Topics128,049
Posts1,055,634
#1522339 10/18/2023 12:01 AM
Pretty suddenly my engine started to sputter at high rpms, if you get on it, it smooths out, otherwise it sounds pretty crappy, kind of sounded like fouled plugs and they might have been a touch, but cleaning and new ones didn't fix problem.
No hesitation from idle or anything like that, no loss of power.
I can't remember exactly now, but it just kind of started doing it when I was still driving it, but parked it for the summer because I was busy.
So trying to figure it out. Points should be fine, changed to an older but ok cap and rotor, new spark plugs, changed in line fuel filter.
What next?
Oh, and also, not sure why, but the rear two spark plugs were discolored on the outside of engine, not sure what could cause that, maybe heat....
1961 261 engine btw, rebuilt about 2000 miles ago
1961 Chevy C40 Flatbed 261
O Online: Content
Probably the condenser. Same symptoms happened to me with a '66 Mustang and '56 Cadillac. Condenser in Mustang only had 1500 miles on it. Modern ones are junk.
Get one of Jon G's 200,000 hr condensers.
1950 Chevrolet 3100 (Ol' Roy)
I have one, actually 2, I should check and make sure it's making good contact.
O Online: Content
OK then. Check for vacuum leaks.
What the carburetor story?
Professionally rebuilt carb, jet bored very slightly over for 261 engine (off a 235). Ran super well, haven't really ran ethanol fuel through it, I'd think it should be good, only a year or so old and it's longest break was this summer. I will definitely check for leaks though, and make sure the vacuum advance is working.
The gas tank should probably be drained and cleaned, but with the filter, unless there's water in it, it should be good. Since it was running fine with whatever was in there before, but just guessing that it's fine is kind if a sure way for problems.
Idle is okkkk, but not as good as it should be.
Riding in the Passing Lane
That can be caused by too much timing. Try running it with the vacuum hose disconnected from the dist vacuum advance. Plug or put a piece of tape over the vacuum outlet.
George
1972 Chevy c10 Cheyenne Super
What does this little tube in the carb do? Took the air filter off for a peek and pretty dirty.
Can see light through air filter 🤦🏻‍♂️
Inside the carb itself doesn't seem very dirty, but that little tube sure is. Not sure what to do from here.
I wonder how helpful eating a healthy diet of dirt has been for my engine.
That tube is a vent to the fuel bowl and should not be dirty. Possibly fouled some passages in the carb. I would take the carb apart and give it a thorough cleaning. Take note of what is in the bottom of the fuel bowl.
I don't know what kind of air filter you have but the stock oil bath filter is the best. Keep the oil level up and they work every time, all the time.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Ok, will do, thanks jethro, I'd like an oil bath one, but didn't have one with the truck when I got it.
My only concern (perhaps unfounded) with the oil bath is mine is the kind you can't remove the element for cleaning. Guess they can be cleaned well enough with lots of sloshing mineral spirits. You seem to have good success with it though. thumbs_up
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
So I took her apart, and there's a touch of silt at the bottom but nothing crazy, Not sure where the issue would lie
The big rigs still use oil bath air cleaners. They never "choke up" with dust. Just clean the bowl and fill with oil. The oil keeps the mesh clean.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
