| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 279 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 279 | I have found 67-72 chevy 3/4-ton truck in a junk yard. It has a v8, automatic, and 2-wheel drive. It has a twelve-digit vin. Is there any way to find out more info on this truck. It most likely has the 4.11 rear end, so I will pursue it for and upgrade for my 47 3600. I suppose I could crawl under it and find a number on the rear end, but you know how junk yards are lol.
1947 3600 Chevy
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | IMHO, if it's a '72 the odds are better if it's a '67.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Nov 2021 Posts: 1,353 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,353 | There should be an option label somewhere like the inside of the glove compartment that would give all the option codes including the rear axle. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | If you are able to squeeze under the truck, big if, you will almost certainly need a wire brush and a flashlight. Very desirable upgrade, hope it works out. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The VIN won't tell you what rear is in the truck, you need to look at the SPI data label on the glove box door for that info. Mike B  | | | | | Joined: Dec 2020 Posts: 279 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 279 | Thanks, I'll go back next week and look into it further. I have not been around this type of truck for years. I never thought to look into the glove box. The passenger door is welded shut and the driver's door is damaged really bad. When did the 17 digit vin come into play? I owned a 67 1/2 ton back in the late 70's. It had a 307 v8, three on the tree, and 4.11 rear end. I'm hoping this 3/4 ton has the Eaton rear end with the 4.11 gearing.
1947 3600 Chevy
| | | | | Joined: Sep 2009 Posts: 5,778 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,778 | lumbersawyer, The "SPI" label Mike B refers to (Service Parts Identification) data labels for this group of trucks lists all the options the truck would have been built with at the factory. Take a peek at this SPI information page along with the last linked web page in the left column. This should help understand what all that gibberish on the label means by referring to the SPI Code List that describes all the options (at least those known to the owner of the site). I found 3 different codes on that page that reflect a "4.11 ratio" rear axle. Your initial search/assessment of the vehicles SPI label in question could show you at least what it came with from the factory without getting down in the dirt/weeds.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2020 Posts: 279 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 279 | Thanks, according to the spi data it looks to be a 71.
1947 3600 Chevy
| | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | Thanks, I'll go back next week and look into it further. I have not been around this type of truck for years. I never thought to look into the glove box. The passenger door is welded shut and the driver's door is damaged really bad. When did the 17 digit vin come into play? I owned a 67 1/2 ton back in the late 70's. It had a 307 v8, three on the tree, and 4.11 rear end. I'm hoping this 3/4 ton has the Eaton rear end with the 4.11 gearing. Most who have studied it a bit or experineced it say that 1968 was the first year of somewhat uniform "Vin numbers" If you were to look at the vin numbers of early 60's GM, Ford and Mopar, IH and AMC vehicles there was no continuity between one and the other. That changed in 68 and has changed at least twice since. Until around 1954 most vehcles just had serial numbers used as vin numbers and as we with older rigs all know a number of states used engine serial numbers while others used the body serial numbers. The spid as onthers is your go to on this though.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
