5 members (2-Ton, 39suburban, pauld, 2 invisible), 176 guests, and 5 robots.
Topics128,186
Posts1,057,305
Members48,467
I was informed by Accuride that the wheel design for my 1946 cabover was made to mount the wheel and support by the wheel studs. To my disappointment they continued to inform me that the new wheels that fit my old wheels dimensions would not work because the new wheel is designed to rest on the hub. Whats the possibility of using a class-A mobile home hub or alternate hub on my old axle? Whats available that will fit and free me from my search for old new wheels? :hammering:
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
CAJUN CRAW FISH,
I would think a crafty machinist could make some type of adapter that located off your wheel studs and provided the needed load bearing shoulder to satisfy the Alcoa wheel requirements. This would be cheaper than adapting completely new hubs. I'll bet Grigg will show up with a 10 minute fix for this dilemma...he knows his big bolts and wheels! smile
Stuart
There is a company called "Correctrac" or is it "Correctrack", and they make spacers or adapters that bolt on to existing studs and provide a second set, spaced outwards by 1.5" or 2". I am under the impression that they also make centering rings that bolt on to provide hub centering. A lot of their business is with people towing large RV trailers and using 8 lug hubs. I have a set that I am someday going to use on the rear of my truck. I am having difficulty finding their website because there appears to be an IT equipment company with the same name.
1951 1 Ton Completed
Just located another company after looking for the site you mentioned truckernix, the site is Chromewheel.com Some unusual looking stuff there but adaptors that you spoke of are there olso.
Photobucket
My quick search found a site that says these spacers are not made any longer. The pictures don't appear to show any hub centric features.
The center hole on the new metric wheels are larger and will not hold the wheel centered. However you can have the stud holes beveled and change to bud style lug nuts this will hold the wheel centered. It is done all the time with big truck wheels when guys find good deals on hub piloted wheels and have a truck that uses buds.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
My only point was that I was under the impression that Correctrac made centering rings. I believe that I saw this in one of their responses in an Rv magazine.
HevyHauler seems to have the ultimate solution.
