4 members (Charles in CA, IHPWR, Otto Skorzeny, 1955 1 Series), 155 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#1522459 10/19/2023 12:19 AM
So I purchased new hardware and door cards. Sadly disappointed. Just a piece of pressed cardboard. That just wasn't going to cut it for me. So I made my own. Next I'll figure out an armrest. Already tried the aftermarket before. Cheap plastic. Mine broke. I would like to use the TF armrest but can't find measurements for screw holes. Not sure if they would bolt up. Anyone used something different that bolted on. Thanks
breezy #1522503 10/19/2023 11:53 AM
I have not gotten that far with my doors but really like what you made to replace the cardboard type door cards.
Any concerns with the latch lever dragging on the back side given the path the connector strap from the latch to the inside release handle?
1949/50 3600 Project
Follow in Project Journals
breezy #1522505 10/19/2023 12:06 PM
Yes I had forgotten about that when I built these. If you look close you notice there is a slight bend in the panel. I layed it on the edge of my lift kneeling on a 2x4 I just massaged it a little. That keeps it off the door mechanism. Also stacked 3 large washers on shaft to hold it out. It was a learning experience but I like a challenge.
breezy #1522509 10/19/2023 12:53 PM
I can’t remember I got mine from but I went to a junk yard years ago and used a set from a older junk car the threaded holes are there to measure just have to go to a older junk yard we’re they have some 60,s cars and find a set .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Those appear to be TF armrests. All the salvage yards have crushed out in my part of the country.
The arm rests were from a car and not from a TF .I am think they are from a 70 Toyota Corolla .
"The Journey"
Follow in the DITY
breezy #1522623 10/20/2023 12:44 AM
I bought the repo arm rest and followed the advice of others on filling the plastic cavities underneath the rest with epoxy. They seem rather stout now. Time will tell.
~ William Moore
1950 Chevy 3100
Truck Tuesday Reports
"Bringing 'OId Blue' Back to Life"
breezy #1522624 10/20/2023 12:48 AM
Seems like a good idea.
Moderated by  ndkid275, Phak1
