Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, Wayne67vert), 143 guests, and 2 robots.
Topics128,281
Posts1,058,464
Members48,490
#152243 04/25/2007 3:56 PM
Hello, I was wanting to pick the brain of the split rim experts out there. I just took my split rims for my 1960 two ton to the local truck shop and they refused to touch them. Saying they were "widow makers". I have since found an ag shop near me who will. Question: When the rims are cleaned and painted ( sand blasted, epoxy primed, painted) and assembled corectly is there any thing to be worried about? I have 3 piece splits on my 46 and have never heard any troubles from them. Are the two piece type that join in the center that much more dangerous? Thanks for all replys!
240,000 worker bees!
1960 Two ton Chevy
#152245 04/25/2007 5:42 PM
AS LONG AS they are in good solid, straight shape, you should be fine. the danger comes from rotted out rims, or rust/damage causing the two halves to not seat together properly.
Now are they as safe as modern drop centers? No.
#152246 04/26/2007 3:54 AM
Junior Member
Junior Member
They probably just refused to mess with them because they really are a a pain to change. The lock ring is actually pretty dang hard to pry out of there, then you got to get the old tube out of there (its usually pretty darn messy and slippering inside the tire too), put the new one in, then put it all back together and pry the snap ring back in place. Usually you end up destroying the snap-ring, and i doubt most modern truck shops would even stock the ring for your wheels, or even the tires or tube for that matter. Trucks have been running solid rims for a LONG time now, not many shops would even know how to change a split rim.
#152247 04/26/2007 3:56 AM
Apprentice
Apprentice
I concur with the other guys. I've been working with split rims since about 1970 and have always treated them with respect. They're kind of like rattlesnakes, you need to know how to handle them safely. Once you have them cleaned up and remounted, keep an eye on the pressure on a regular basis. If the tire pressure drops too low (some say below about 60% of the recommended pressure), the rims can shift and reinflation can then become VERY dangerous. I'm running two-piece rims now and have no trouble.
#152248 04/26/2007 4:30 AM
I personally would stay away from the two piece ones that split in the center. People give away the lock ring type, so I would switch to those, they are safer. If for some reason you don't want to switch, as the others have said, when they were new there was no problem, so make sure they are in great shape, and treat them with respect.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#152249 04/26/2007 4:51 AM
if you keep them in good shape no problem, the ag shop will do them, cause most big farm trucks are still split rim, most regular tires shops have gotten away from split rims
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
