3 members (68ironhead, Otto Skorzeny, Jerry 53), 72 guests, and 2 robots.
Topics128,094
Posts1,056,489
Members48,444
I have a 55.1 with the stock 235 and want to perform a 6v to 12v conversion. I’ve read through various articles and some recommend a GM 10si 2 wire alternator while others recommend a one wire alternator. I’m no electrician and would love to hear the forum’s thoughts on which alternator (1-wire or 2-wire) should be used for this conversion AND specifically why you advocate for your recommended alternator style. Please also elaborate on any and all specific companion components that are needed in order to compliment and safely complete your recommended style of alternator. Thanks in advance and I appreciate everyone explaining your preferred setup in “plain language” for me to understand.
I put a one wire in my 47 that has a 235 in it. The reason was they are very easy to install. I ran a #10 to the starter post and that’s all it needs. I have done the regular type on my tractors but that type requires a activation wire from you ignition switch. I wanted to keep it simple.
1947 3600 Chevy
One wire alternators
pro: Simple. Only need to hook up one wire. #10 wire to the starter post as Lumbersawyer suggested above is as good as anywhere and better than most.
con: Voltage level is sensed at the stud on the alternator where the wire attaches and doesn't allow for any downstream voltage losses, so lights may be a little dimmer, etc. Many need to be spun faster than a 3 wire alternator to begin charging.
Two wire alternators Never seen one, unless you are talking about a "one wire" alternator with an output for the "ALT" light on the dash. Most one wire alternators have it.
Three wire alternators
pro: Has a "sense" wire that can be hooked into a remote area of your wiring harness. It will regulate to the voltage at this remote point instead of at the alternator itself resulting in somewhat brighter lights, etc. Many will start producing a charge at a lower RPM than a one wire alternator. All support an "ALT" light on the dash.
con: More complex to connect, 3 wires instead of 1 (or 2).
I use a 3 wire and connect the "sense" wire at the power input to my fuse box.
