3 members (greenie-reddy, Gray_Ghost, Brian Moore), 146 guests, and 3 robots.
Topics128,057
Posts1,055,808
#1522325 10/17/2023 11:10 PM
Hey bolsters-
When I got this 53’ GMC dump truck, it already had an electric fuel pump wired in under hood.
So I assume the mechanical pump failed at some point.
I am doing some other engine repairs right now and figured if I could delete the electric pump it would be nice to have the original setup work.
If feasible.
Here are a couple pictures of it.
It has four threaded ports?
The glass fuel bowl has two ports on either side…
That would be obviously in/out.
But what are the two fittings on other end for?
They actually have vacuum and pressure when manually operating pump lever.
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
That's the fuel/vacuum pump. I'd like to have one, but they're kind of hard to find. Top ports with the glass bowl are for fuel and the bottom ports are for vacuum. Helps keep the wipers going when the throttle is mashed down. Probably found on big truck with vacuum operated 2 speed rear axles as well. You can get a repair kit (if needed) from Then and Now Automotive.
Brian,
Consider either keeping electric pump or get yours rebuilt. I bought (and returned) 6 bad fuel pumps in a row. I gave up and went electric. Hopefully you have better luck than I did!
Chris
Chris,
Funny my cousin went thru 3 mechanical fuel pumps from the FLAPS.. and finally got a good one.
Klhansen, thank you for the link.
I do want to rebuild this unit.
Good info, never been let down posting questions on here!
Love this site!
Brian
Virtually all modern fuel pumps are junk right out of the box. Brand name makes no difference.
I had two modern pump fail and then had Then and Now rebuild my mechanical pump. So far it's worked for 4 or 5000 miles without a problem.
1950 Chevrolet 3100 (Ol' Roy)
Ok…. Kl hanney..
I got the rebuild kit from then and now automotive for
My fuel pump/vacuum pump.
Kit was awesome and their YouTube video with very detailed instruction was superb!!
Loved doin business with them.!!
Very standup company and give them an AAA+!
Anyhow, pump is ready for reinstall as soon as I can order new cam and lifter set.
Thanks for the connection .
Brian
Glad to hear it. I'm sure it will perform well for you.
