8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible), 67 guests, and 1 robot.
Topics128,090
Posts1,056,014
Members48,430
#1521525 10/12/2023 1:46 PM
before starting up for the first time after rebuild, looking for a oil pump priming tool or advice on what to use on the 216.thanks
Family truck 1953 1/2 ton w/216
Buy a flea market flat blade screwdriver about 8 inches long, remove the handle (most can be driven off the blade with a hammer) and chuck the blade into a 1/2" drill motor. You might need to grind the business end of the blade a little to resemble the flattened end of the distributor shaft. Spin the pump clockwise until oil pressure builds up and oil starts to dribble from the weep holes in the rocker arms. Keep a firm grip on the drill- - - -when the oil galleries pressurize there will be a sudden, heavy torque on it.
weewilly,
Just a note that I have moved your post to the Engine Shop forum for the best on-topic further discussion and help.
~ Dan
1951 Chevy 3 window 3100
weewilly #1521619 10/13/2023 12:16 AM
Many years ago I made a primer tool from a spare distributor. Grind off the head of the pin on the gear, drive the pin out, remove the gear and gut the rest of the distributor until you have just the housing and the shaft. Install the shaft, connect your drill to the top of the shaft and away you go. Little more stable than the screwdriver method, which definitely works, but I just like a dedicated tool.
Mike
I have the old pump, I want to make a tool to drop off at mechanics. How long should it be to drop in once he removes the distributor. The tool is a priming tool but I had to grind down because it was too fat. Now it fits well into the old pump. The tip is perfect but I am wondering if it is long enough. Thanks once again.
Use the distributor as a reference- - - - -the priming shaft needs to be at least as long as the distance from the end of the shaft to the top of the distributor housing. It could be three feet long and it would achieve the same result. I usually grind a 3-cornered flat area on the drive end to keep the drill chuck from slipping under a torque load.
"Common sense is pretty uncommon these days" ! I don't know who said that, but he was right!
Sorry, I just read Jerry's post again and see 8". I'll make sure I grind it back to that point and more.
I don't have the distributor. That's rebuilt and back in the engine at mechanics. May just go with you first recommendation and use the foot long screw driver.
I just measured a distributor- - - - -it's 9 inches from the top of the shaft where the rotor mounts to the tip of the oil pump drive tang. The distance from the vacuum advance bracket (top of the block) to the pump drive is 5 inches, which puts the rotor 4 inches above the block.
