0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#1522077 10/16/2023 1:17 PM
My '57 Suburban needs front fender patch panels. Several are available online, and I wonder if there is a better brand, or a brand to avoid. Prices also vary from around $50 to over $100 for one piece!
So, where should I order from? I want to spend as little money as possible (of course!), but I do not want to end up with bad parts that need a lot of work, because, as I do not weld, I also have to pay for someone to get the job done...
Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
wave1957,
Just a note here that your post has been moved to the Paint and Body Shop as the best place for your question and replies by fellow Bolters.
Am sure folks will reply back soon. wink
~ Dan
1951 Chevy 3 window 3100
Which part of the fender needs a patch? Most of the vendors get their parts from the same supplier.
I always use the three strike rule, if it needs the heel, brace and eyebrow I'd look for a better one. If you have to pay for body work, it's almost always cheaper to just buy a complete new fender, at $100+ per hour shop time it doesn't take long for the patch job to cost more then a new fender...same with doors.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
They both need the lower rear patch.
As for buying a better fender, I am in France, so finding a good old one is not an option; a new repro is horrendously expensive and the shipping is worse! So, asking for a friend (not a body shop) to weld in the 2 patches is really the best/only option.
What Mike B said about patch panels usually coming from the same factory overseas (not the Atlantic.) Although sometimes there are differences. Dynacorn brand is generally good quality.
Pm sent
