6 members (Nick in Manitou, Phak1, Otto Skorzeny, Hush, MickeyP, 59 fleet), 66 guests, and 2 robots.
Topics128,188
Posts1,057,331
Members48,469
Page 5 of 7 1 2 3 4 5 6 7
What an exciting day yesterday. She came alive for a couple shorts. [VIDEO]
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
That first time the engine runs is a great feeling. Looks like you have a really good helper there.
1949/50 3600 Project
Follow in Project Journals
Unfortunately, she only shows up for the exciting stuff. Not sure where I got my interest in cars from? My parents were never interested, none of my in-laws are, and my kids don't seem to be.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Well. After three weeks I have all of the bad reaction areas sanded, filled, primed, sealed, and epoxy painted good enough to store them away and work on other things like the bed and cab. Had to have a new Alt sent to me, then the starter quit so a new one of those is in the works as well. Lots of small pieces sprayed. these are the eye candy.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
It's going to be too nice to drive.
~ HB
1962 Chevrolet C10
1962 Suburban
Thats why I wanted this epoxy bed liner. Will be super rugged.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Got the undercoating done on all the small parts finally. They are cured and stacked away.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Parts are being stored and stacked. Bed is sanded and sealed for epoxy next weekend. Last but not least I have the steering wheel mocked in.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Got the bed headed in the right direction. Many light coats 4 to 5 hrs apart seems to be the way to go. No runs, no drips. Have a few color variations, but they should be fixed with one last shoot once truck is all together. Time to get the bed sitting on the truck again and get the cab over in the heated side to get the same epoxy on it.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Last time the cab is coming off. Final bodywork in the next couple weekends and then paint. Have the IR heater curing paint from last weekend.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Got a fair amount of time this weekend. Built a tent on the bed so i.could get sanding on the cab seeing the epoxy isn't cured yet. Put the heater in there in hopes it traps more heat and cures things. Got the B pillar dents straighten out with some help. Masked and prepped for undercoating. Lastly, back of the cab and roof started the sanding and skimming process.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Well, I burnt the paint on the tailgate trying to cure it last week. Got the undercoating done today and started on seam sealing the drip edge.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Bummer on the tailgate paint. One step forward and two back. frown
Last bit of bodywork complete and cab has been primed for the last time. Blocking it next weekend and color over Thanksgiving
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Undercoating was a very satisfying part of my 1965 project (ongoing build now in it's 13th year).
Heated garage but I have found I need a tent amd more heat to get the paint to cure. That got done this weekend after my shoulders could not take any more sanding
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Got some color on the cab, hyd clutch into the firewall and attached to the pedal.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Started getting things back in place today.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Unconventional Thinker
Looking good!
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Got it moving under its own power this weekend. Clutch is finally bled correctly.
After giving up on the brake bleeding I began a little assembling. The pile of parts stacked got a few fewer!!!
Maybe the correct video of it moving? CLICK HERE
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
That has to be a great feeling! I am hoping to be able to do something similar next spring although I plan to have a steering wheel and brakes but similar to you no bed, no doors, no front fenders, etc. on that first "will it move on its own" experience.
Got more assembled last weekend. Had to get creative in massaging the door into place. Next is to find all the parts to rebuild the steering column.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Looks good. Ready for spring
~ HB
1962 Chevrolet C10
1962 Suburban
Let's see. Door limit thingies check. New tailgate hardware installed check. Most of the interior AC stuff installed check. Brakes still fighting me check.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
RLB Offline
I'm sure you'll get the brakes figured out on the next go 'round. Looking very good otherwise.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
Got after the engine side of the ac stuff. Some of it does not make sense from directions. I didn't like the heat valve getting close as it is to the header, but with everything else going on I think it's alright. I had to move sensors around and rob nipples from my 283 to make it all work. I think it's all dry fitted. Back off to paint it all black. While radiator was out I will paint as well.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
It's the little things that get you excited. I now have a throttle!
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Got the new digital cluster fitting into place.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
AD Addict & Tinkerer
P Online: Content
You’re making great progress and your truck is looking awesome. Keep up the good work!
Phil
Project Journals
Stovebolt Gallery Forum
Going backwards. Giving up on the epoxy paint I was using. Too challenging of a product for this novice. Sanding all the runs out and scuffing everything in so I can simply paint.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Three weeks later and I am still sanding. Getting closer to good enough to squirt again. Got my door art today. Can't wait till it's painted so it can go on.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Interior, door.jams were shot yesterday. Paint is so much easier than the epoxy I tried to do. Interior was.put back together today.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Pieces are all the same color despite what the pics show. Painting went awesome.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Looks great!
Originally Posted by Alanjmt
Looks great!
Pretty happy. Actually very happy.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
That truck is going to be too purdy to drive NH roads.
~ HB
1962 Chevrolet C10
1962 Suburban
What paint did you use? Looks great!
Looking good.
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
Omni. Was able to mix the correct color. I have a friend with an original 66 same color, hardly any miles on it. It's a spot on match.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I am setting. It up to drive through the year. Probably won't, but I will be able to if I want.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Moderated by  Phak1
