6 members (TUTS 59, Jay R, 2-Ton, Gdads51, JW51, Wally / Montana), 85 guests, and 3 robots.
Topics128,083
Posts1,056,332
Members48,442
#1522016 10/15/2023 9:53 PM
Do I need to use both the insulator block and gasket underneath the base flange of this Carter? (goes on a 235) Either way, one of the two holes (circled in red) is going to get covered up. Should they both remain open to intake vacuum?
Jon you sent a gasket in an envelope with the carb but I've either lost it or thrown it in with my other gaskets, so I'm not even sure the gasket in the pic below is correct.
Can cut a gasket slot so the hole on the left is open, if need be.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Carburetion specialist
Use the gasket pictured; it is OK for the other hole to be covered.
Jon
The Carburetor Shop
Thanks for the reply. smile Use the insulator also?
Matthew 6:33
The use of the insulator would depend on if needed to make the linkage work (height) or if you want it to help prevent heat soak.
Jon
The Carburetor Shop
Yes, will need/want insulator for both reasons. Appreciate the info.
Matthew 6:33
