3 members (KEVINSKI, MikeE, joe apple), 102 guests, and 2 robots.
Topics128,034
Posts1,055,551
1948 GMC 1/2 ton. Noticed my leaf spring bracket was loose on frame.
What's the best way to repair this, grind off rivets and use nut and bolts, or weld it to frame?
I had the same issue, ground the rivets and punched them out then used grade 8 hardware to re-secure. Welding would probably be iffy, the bracket is cast something or other.
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
I'm going with that. Seems more secure with nut and bolt.
I would bolt it on with grade 8 bolts like was said. There is a reason it was riveted and not welded originally. It needs to flex a little and welds will over time crack.
1947 3600 Chevy
The reason was economics. Rivets were cheaper than welding processes. That and welding on the flange of a frame weakens it, which is what would be the reason for cracking. Welding should only be done on the vertical section of a frame, and judiciously if any.
Make sure that you are able to find bolts which are a tight fit between the non-threaded portion of the bolt and the holes in the frame and the bracket. Any slack in the holes will lead to these holes to become larger over time.
The original rivets were installed under great pressure, resulting in a very tight fit. You will discover this when you try to pound them out even after drilling and grinding on them.
Got it, thank you.
Thanks for the input guys.
