3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#1521900 10/14/2023 11:56 PM
Had gas gauge rebuilt by Jim Carter
Hooked it up as they said and as the old one had been
When I power it up it tries to go from empty to less than empty
Battery hooked up negative ground
Power goes to the "E" end of the gauge, sending unit wire to the "F" end.
Thank you
That’s how it’s hooked up
I’ll call Jim Carter tomorrow
OK, done everything suggested by Jim Carter to fix the issue. All was hooked up right. The only thing I have not done that they suggested was to pull gauge back out and sand under it to make sure it has good continuity between it and the inside of the gauge cluster. Could this really be the problem? Thanks.
O Online: Content
Yes. Poor grounding is the cause of most electrical problems in cars.
1950 Chevrolet 3100 (Ol' Roy)
