1 members (klhansen),
160
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Do the 1947-1953 Cabs, Doors, Hood, Front Fenders and Grills interchange between 1 ton and 3/4 ton trucks. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | YES...big bolts are 1-1/2 and 2 ton. Mike B  | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | When shopping for parts or whole trucks remember to confirm the truck size yourself Many 1-1/2 ton trucks are advertised as 1 tons online and in person and people are too lazy to research the door tag number before posting for sale -s | | | | | Joined: Apr 2004 Posts: 5,089 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,089 | For Stovebolt categories, we consider Big Bolts to be: " For topics related to 1.5-ton and larger" ... now, how any of that relates to the OP's question, well, that may be for discussion in Paint & Body Shop. Will defer to those folks.....
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Mike; when you answer yes does that mean a 1.5/2 ton cab, fenders etc are the same as a 3/4 ton? Thanks everyone for the help. | | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | The cabs are the same for all sizes except for COEs. The break point for hood and fenders is 1/2 ton thru 1 ton same and 1-1/2 ton and 2 ton the same. So you can’t use 1-1/2 ton or larger fenders and hood on a 1 ton or smaller truck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Hi GWWirth My apologies if it’s not yet clear as mud I’ll try to explain it the best I know but also if you let us know what specifically you are trying to do we can be more precise to your situation
The cab only is common to all truck sizes except coe,
1/2 to 1 ton share cab fenders hood, basically all the sheet metal that looks the same is the same Box parts are different lengths and some minor differences between the sizes The bumpers all interchange however the 1 ton bumper is thicker than the 1/2 and 3/4 ton, the chassis is different for all three 1/2 , 3/4 and 1 ton so you can’t swap the bumper mounts, nor major suspension parts.
The 1-1/2 and larger share their larger counterparts sheet metal parts between them but it’s all bigger stuff and the chassis naturally all larger and very few parts are common to the smaller trucks except the engine itself and some nuts and bolts, etc. -s | | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | Moving over to Paint and Body, where it'll be more on topic.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | GWWirth, Sorry to be a bit late to the conversation, but I think folks may be confused as your "title" asks about "Body differences between Big Bolts and 3/4 ton", but the actual question asks: Do the 1947-1953 Cabs, Doors, Hood, Front Fenders and Grills interchange between 1 ton and 3/4 ton trucks. To hopefully clarify the replies given, maybe this better explains the info: Neither 1 ton or 3/4 ton trucks are considered "Big Bolts", so 1947-53 Cabs, Doors, Hood, Front Fenders and Grills DO interchange between those sized trucks (along with the same items on 1/2 ton trucks). "2ManyTrucks" notes the exception involving "bumpers" which is important to know for these sized trucks. "Big Bolts" (1.5 ton and above trucks not including COEs) for 1947-53 do share the same "Cabs and Doors" of 1/2 ton thru 1 ton trucks, but DO NOT share "Hood, Front Fenders, Grills or Front Bumpers" (plus related under hood and fender parts) with the smaller 1 ton and below trucks. "Big Bolt" fender, hoods, grills, bumpers and related under sheet metal front end parts are larger sized to match the larger chassis and those will not fit 1 ton and below sized trucks. If it might help visualize the differences, check out this conversation I found with some pictures that may help see some of the differences. Clear as mud???
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | Dan, that post with the pics over on HAMB says it all. Good find. As one poster over there, said. Pictures are worth 1000 words.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | All very clear. Thank you for the help. I'm just researching at the moment. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | Mike; when you answer yes does that mean a 1.5/2 ton cab, fenders etc are the same as a 3/4 ton? Thanks everyone for the help. I was answering your first question...are 1/2 thru 1 ton are the same, "YES" cab and front clip are the same. Then wanted you to know Big Bolts are thought of as 1-1/2 and up trucks. Their front clip is not the same as 1/2 thru 1-ton. Sorry for the confusion. Mike B  | | |
