8 members (BarryP, NorCal52Suburban, Hanks custodian, Bill Hanlon, rfs56trk, Donf, Frank50, Gazz), 122 guests, and 3 robots.
Topics128,136
Posts1,056,745
Members48,454
It doesn’t have to be perfect, just enough to spray the primered surface with original color so my patina truck looks a little better. Others dings I can work with but this one in the tail gate has me baffled.
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
I did a similar one by drilling s 1/4" hole in the opposite face of the tailgate and put a punch through from that side to pound it out. When I was done, I welded the hole shut.
Wasn't perfect, but looked a lot better than when I started.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Jason's fix is one approach to that tough dent.
Another is to remove one end piece from the tailgate to be able to insert an anvil (or dolly in the body shop vernacular) inside the top roll and work the dent out. I had a bed rail that was flattened and used a large ball bearing that I welded to an adapter screwed onto a slide hammer. My dent wasn't as deep as yours. Here's some pics of that approach. You'd then need to plug weld the end piece back on. Either way, it'll be a lot of work.
The 16 gauge metal will be pretty hard to pull out with weld studs and slide hammer, but it might eventually work.
FLATTENED BED SIDE EDGE
FABRICATED TOOL
DEPTH MARKS ON SHAFT OF SLIDE HAMMER
MARKS ON BEDSIDE ROLL TO LOCATE THE BALL INSIDE
Insomniac
Insomniac
I used Kevin's method.
With the ends off, a piece of iron pipe (borrowed from a bar clamp) was inserted inside and used as a dolly. Yes, it was a big job. A repro tailgate would have been an easier solution for us.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
What am I missing here? How do you work the dent out with a dolly when you don't have access to the back of it?
The dolly (in my case the ball bearing) goes under the deepest part of the dent and you hammer around it on the high spots. It definitely takes a while, but the dent will come out eventually.
Weld on studd puller
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
So far I like Jason’s suggestion. If it fails I can still go more invasive. If needed, where would I easily find a bearing that diameter?
I found that bearing on either Amazon or eBay. Don't recall exactly, as it's been a few years ago.
Tough problems like that I take a high speed grinder with cut off blade, cut it out and and put in a new piece or straighten the old and weld it back in. But that’s me.
1957. GMC F350
Cutting and welding is another option.
