2 members (NJC, greenie-reddy), 159 guests, and 4 robots.
Topics128,260
Posts1,058,287
Members48,485
#1521464 10/11/2023 11:55 PM
Is this called an offset stem on the tube or do I order the tube with the 90 degree stem. Thanks.
Family truck 1953 1/2 ton w/216
That stem is the correct one for single wheel applications like the one in the pic. The 90 degree stem is usually used on dual rear wheel setups so the stem doesn't drag on the brake drum.
Ok, good that's what was ordered.my dad had those on his milk truck.we used old tubes for sledding. The stem was a bit of a hazard -I wasn't sure since it's out to the side. Thanks again.
