5 members (Charles in CA, Gdads51, J Lucas, 78buckshot, walter74), 97 guests, and 3 robots.
Topics128,127
Posts1,056,671
Members48,450
#152133 04/18/2007 6:00 PM
Where is the indentification/serial number on a pre- '47 A.D. truck? Texas requires these to be indentified according to motor number. How can I find out for sure what year model this truck is?
Matt
"Brunhilde II" '59 Viking 60
To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
#152134 04/20/2007 4:13 AM
Former Workshop Owner
J Online: Content
Motor number is on the engine by the distributor. The truck model-serial number tag should be on the right side cowl. Passenger side under the hood. This info is available in the "tech tips" section of the Stovebolt.
A lot of Art Deco's, have had their ID tags removed, as they were only held on with screws.
Good Luck
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#152135 04/20/2007 5:08 AM
Ditto on the above comments. My '39 has a replacement plate on the cowl that has a partial VIN, but apparently enough that AZ titled it that way.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
#152136 04/20/2007 3:48 PM
Thanks guys.
I found the part about the id plate being on the cowl but couldn't find the part about the motor number. Would this also be true about a '54 6100? The plate is on the door post but that is not the number that TxDot uses. Thanks again
Matt
#152137 04/23/2007 3:24 AM
The plate on the cowl is gone. The motor number is stamped (not cast) on the block at the back side of the distributor. It is DEA 621296. Can anyone tell me what I have? I run through all of tech tips and can't seem to find it.
Matt
#152138 04/24/2007 2:57 AM
I
I Offline
You need the casting number to really know what you have.
Should be on the same side of the engine below the GM marking
#152139 04/24/2007 3:00 AM
I
I Offline
That will just tell you which engine you have. Without the VIN tag you won't know the year of the truck.
If you're lucky the engine will be orginal, but it's no guarantee.
