3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1521343 10/11/2023 12:08 AM
I have a 1969 chevy c10 that uses oil badly, probably a quart to 700 miles. It has about 130000 miles on the 250 6 cyl. It does not smoke when running or driving but on start up it blows black moisture out the tailpipe. Does this need an overhaul? It doesn't get driven much anymore. Any advice?
56trucknut #1521346 10/11/2023 12:18 AM
I'd recommend you start with a leakdown test. If it is coming out the tailpipe then it is getting into the combustion chamber(s). That is valves or rings. A leakdown test can help ID if the rings are good or not.
There can be assembly issues (incorrect rockers, incorrect oiling setup, valve seals, valve guides, etc) that lead to oil down through the valves and a decent number of them are fixable without a full teardown.
With that many miles on a 250, if it has not beem rebuilt before then it is probably due. Worth doing some checking first though.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Fibonachu #1521347 10/11/2023 12:25 AM
What is a leak down test?
56trucknut #1521348 10/11/2023 12:27 AM
Check the PCV valve and the crankcase ventilating system. If pressure is building up in the crankcase from a malfunctioning vent system it can cause excessive oil consumption on an otherwise good engine. Also look for oil leaks from the timing cover, valve cover, and bell housing- - - -high crankcase pressure can cause those places to leak. It's not uncommon for sludge to build up in the vacuum line between the PCV and the intake which prevents good ventilation air flow.
56trucknut #1521361 10/11/2023 2:01 AM
Riding in the Passing Lane
Check out the simple things. If any of them don't solve the problem, I would not worry about it. One qt. every 700 miles was not considered excessive back years ago. The manufactures would not warranty if that's what it used. You don't drive it much so a qt. in about a month is not to bad.
Try using 10w40 oil in the winter & 15w40 in the summer.
That black moisture coming out the tail pipe could indicate a rich carb &/or choke.
George
1972 Chevy c10 Cheyenne Super
56trucknut #1521386 10/11/2023 12:50 PM
Give this web page a read (video included). Pretty much thoroughly explain what a leak down test is and how to get 'r done. thumbs_up
~ Dan
1951 Chevy 3 window 3100
