2 members (78buckshot, 1 invisible), 390 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
#1521290 10/10/2023 5:41 PM
I'm wondering if anyone has seen this. When I removed the head on my 216, each piston was stamped with the associated cylinder number, 1 through 6. There was also an "M" stamped on top of each piston. Was this maybe from a rebuilder stamping the number to use to reinstall the same piston in the cylinder it came from?
Numbered Pistons in 216
Dave,
Since this is a direct "engine" question, I have moved it to the Engine Shop forum for further conversation and answers from fellow Bolters.
Good luck in your search for an answer! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Seems like a Sharpie would have been an easier and better choice to mark pistons than putting them in a vise or something and then punching a number.
I'd suspect they were made that way but what do I know?
1950 Chevrolet 3100 (Ol' Roy)
Sharpies didn't exist when those pistons were stamped, most likely. If I was going to do something like that, I'd do it before I removed them from the engine. No idea why there's an "M", but the piston/rod assembly has to go back onto the correct connecting rod journal to keep the bearing fit correct, so numbering them is a really good idea..
Pistons in GMC sixes from the 40s and 50s came with two numbers stamped on the top. 1 thru 6 for the cylinder number they were installed in at the factory and another single digit for the actual piston size. Below is the size chart for 270 and 302 engines.
Does that M happen to be located on the manifold side of the piston?
Yes, it was on the manifold side. Good catch!
Anal retentive rebuilder probably did that. It's important on some engines to make sure that the connecting rod is installed the correct way.
I wonder if he stamped the connecting rods to make sure that they were installed to match the stampings on the pistons.
