3 members (Dennys28, Southerntruck, KEVINSKI), 82 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
#1520334 10/04/2023 4:23 PM
If anybody has their 55 - 57 bench seat out. Would you take a picture of the rubber vent in the bottom pan? I might have to make a couple of those and the retainers.
Thank you,
Larry
LA does that vent look like the hole in the picture below. I’ve been trying to figure out what it’s far and your question sparked my curiosity.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Doug,
Check the picture I attached in Larry's Swap Meet thread.
Your 1954 seat and cab floor area are different than his Task Force truck.
I should have posted the picture here since Larry asked (wasn't from a truck of mine - just a pic I found on the web).
~ Dan
1951 Chevy 3 window 3100
Thanks, Dan. I was about to ask Doug what that was from. AD trucks sure look different.
Larry
Ahh. Still looking to figure out what that hole is for before I cover it up.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
You might have better luck with a new post separate from this one since it’s a different series of truck. I can’t help because I’m not experienced with the Advance Design trucks. Good luck with your project.
Larry
Larry, Check your PMs wink
~ Dan
Moderated by  ndkid275, Phak1
