1 members (Phak1), 113 guests, and 2 robots.
Topics128,266
Posts1,058,386
Members48,485
I am getting ready to put my new kingpin bushings in on the 58. Looking at the Service Manual, it says to use lard as a lubricant for installation.
Any ideas what property of lard makes it appropriate for this? I could go buy a tub of lard and make a disturbing amount of chili with the rest, but it seems like there should be a better way now.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The grease you plan on putting in there anyway will work just fine. Not much overthinking with the king pin process.
Buy a small tube of an anti-seize compound like Never-Seez. It's only needed to prevent galling of the OD of the bushing as it's pressed into the spindle. Just like Brylcreem- - - -"A little dab'll do ya!"
Back in the dark ages, we used lard in the deep fryers at my grandparents' restaurant- - - -it gave the French fries a lot better flavor than vegetable oil!
Now, Jerry... more and more of today's Stovebolters haven't got a clue what Brylcreme is, or was. 😵‍💫
Lard was my mom's secret to flaky pie crusts... and biscuits.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
"Brylcreem – A Little Dab'll Do Ya! Brylcreem –
You'll look so debonair.
Brylcreem –
The gals'll all pursue ya; they'll love to run their fingers through your hair!"
I have neversieze on the shelf. If the goall is to prevent galling (which makes sense) I will just use that and go.
Thanks!
A mixture of unsalted lard and a few drops of 30 weight oil to the consistency of Jell-O makes one of the best drilling and tapping lubes around. When the drilling job starts to smell like frying bacon, the pressure on the drill press quill feed is just about right.
