1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1520289 10/04/2023 6:08 AM
I just came across this method on YouTube - that was new one to me and looks like a great method!
I did the bread trick on mine and it worked, but this sure looks easier!
(no affiliation with that YouTuber - just came across inadvertantly and was impessed!)
Pilot Bushing Removal
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission
6 Bolt disc conversion with dual master/vacuum booster
12V alternator conversion.
235 engine in waiting grin
That's a slick trick. And the YouTuber sounds like the Bob Ross of engine repair. grin
Where's the fun with that method? Look how clean his hands are. I bet his face and shirt is clean too...
Use a tap. Its easier, just as effective, and just as clean, lol!
Mike
Not everyone has a tap of the right size. I know I don't, but I probably have an appropriately sized nut and bolt in my collection. I'm a cheapskate, so whenever I can pinch a penny, I do. Not afraid of buying stuff when needed, but still.... A tap is probably $15+ if you need to get one.
I like that method the best.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
AD Addict & Tinkerer
I’m wondering since it’s a blind hole on a stovebolt, if there’s enough room behind the pilot bushing to get a nut behind it. Has anybody tried this method on a Stovebolt?
Phil
Project Journals
Stovebolt Gallery Forum
I used a slide hammer hook when I did mine, and there's quite a bit of room there. I'd say enough for a nut to hook behind the bushing.
