6 members (tclederman, Peggy M, MRMEROTH11, Wickedbass, Barney1951, TUTS 59), 78 guests, and 1 robot.
Topics128,068
Posts1,055,880
Members48,428
#1520495 10/05/2023 3:19 PM
I have a 1950 3100 and it's a 6 volt system.
My question is I'm wanting to change out the existing headlight bulbs which are 6006. O'Reilly auto parts have a bulb H6006 which is halogen 6.4 volts can I use these without frying my wiring?
1950 chevy shortbed 3100, 216 with a 3 on the tree.
Riding in the Passing Lane
Yes you can but it would get better results to wire in a pair of relays with them.
Quite being a "Cheapskate" & change over to 12 volts.
George
1972 Chevy c10 Cheyenne Super
Lol this project is nickel and dimeing me.
Welcome to old vehicles.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
You can put in relays, but in my opinion, while that works, it is a bandaid which ignores the root cause of week headlights.
The ground side of the electrical circuit is the problem. It gets worse over time due to rusty sheet metal.
On a stock truck, the ground starts at the battery negative post, then to the frame. From there it has to pass from the frame through the front crossmember, through the radiator support, through the inner fender where the ground screw for the headlights go.
See the problem? That's a lot of rusty intersection to cross through.
I would sooner run a dedicated ground wire from the battery to those headlight grounds on the inner fenders, than to use a relay.
It's worth a try regardless. If it doesn't work you can use that wire to plumb your relays.
That’s exactly what I did Carl after everyone said ground ground ground.
I was having all kinds of problems with non working park and head lights.
I put in a buss bar on each side and ran direct ground wires to them. Everything started working like magic.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
