3 members (Chip O, Charles in CA, 1 invisible),
159
Mod | | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Got the new window in the 51. Found in the inside panel the aforementioned GCG,do I really need it? Classic parts lists these for 47-50. Wonder if maybe a PO put in an earlier door? Thanks Bill | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | aforementioned GCG??
Did you mean to reply to a previously posted thread?
I'm not really understanding your question. If your window is installed, leftover parts are immaterial. Toss them in the proverbial coffee can.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Kevin: The Glass channel guide is listed in their catalog(Classic Parts) for 47-50 trucks, mine is a 51 Was wondering if maybe I don't need it-Thanks Bill | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | There is a metal channel on the back of the door that's held in by a couple of screws on the '51. If that isn't in place, the glass will be loose when it's rolled down. Their catalog is in error, as that's used in the later trucks as well. It goes in opposite the division bar with glass channel on your vent window assemblies. It's shown in the FAM on Section 1, sheet 22.00
