6 members (TUTS 59, AWinLex, Gdads51, Otto Skorzeny, 2 invisible), 67 guests, and 3 robots.
Topics128,181
Posts1,057,177
Members48,465
PA OUTLAW
PA OUTLAW
Hello all have a problem with my bellcrank on driver side of motor under the carb were allthe throttle linkage bolts to the side of the block.The stud that threads into the block does it have a lock washer that tightens to the block and the shoulder of the stud or is just locktited in the block also does anyone have a good picture of this assembley looked in the service booh and factory manual but coudnt find a good picture mine apartenly unscrewed on a sunday drive and it unscrewed then I WAS SCREWED LOL LOL THANK YOU IN ADVANCED!!!!!!!!!!!! PA outlaw
As long as it stays tight in the block, how it does so is a moot point. I'd suggest a good thread cleanup and a healthy dose of red Loctite. Add a lockwasher if you believe in using a belt AND suspenders.
jrhackett,
You might want to edit punctuations in your post - to make individual sentences.
Jerry knows more about Hydra-Matics than anyone here.
You might/might-not be interested in this long-winded, step-by-step rebuild of a 1954 Hydra-Matic transmission. Unfortunately, it does not show the complicated shift-linkages.
I cannot find an illustration of the shift linkages - maybe someone will post a web-link?
Tim, I have a 55.2 Truck Shop manual that has a diagram of the throttle and shift linkage. I can take a picture of it and post it if you (or jrhackett) need it.
Thanks, Kevin,
I have plenty of documentation on the 1954 Hydra-Matic.
The 1955.2 is significantly different:
1954 - enclosed driveshaft
1955.2 - open driveshaft
FYI: I have an illustration (somewhere) of a 21-speed Hydra-matic (used in stone/rock quarries).
As I dimly recall, it was (basically) 2 Hydra-Matics somehow attached to reducer.
Possibly some useful info to answer your question.
This page from the 1929-54 Chevy Master Parts Catalog lists the "stud", "bushing" and "2 washers" (Parts Group 3.582) for the engine mounted accelerator bell crank pivot. All those are 1954 Commercial Truck with A.T. (Hydra-Matic) specific parts.
A snapshot below from the 1947-54 Reproduction FAM (Sect 7 Sheet 3.01) shows in "VIEW A" that those washers go on either side of the bell crank. Haven't found anything to indicate that the stud used a washer to secure to the engine block itself.
Also attached is a better picture from the 1954 Shop Manual (page 7-41) of the Hydra-Matic accelerator & transmission controls in case it could help out in anyway.
Let us know how your "fix" turns out. smile
Dan
1954 Hydra-Matic Controls (from FAM)
1954 Hydra-Matic Throttle and Shifter Controls (from 1954 Shop Manual)
~ Dan
1951 Chevy 3 window 3100
The stud for the bellcrank does not get a washer. Just torqued into place. That it appears to be backing out suggests some binding. How is the bellcrank attached to the stud? It should be by a wire clip. Is the stud and bellcrank lubricated? How about the thrpottle linkage and kick down linkage where they attach to the bell crank? Can you post a photo?
Mike
There are two different studs and two different locations on the side of the block depending on automatic vs. manual transmission linkage.
Thanks, Dan
FYI, Dan's figure from the '54 shop manual looks identical to the one I found in the 55.2 shop manual.
