| | | Forums66 Topics128,094 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | Need some info what bolts are used to attach rear mounts to cab and frame.
| | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | flattop49, Before anybody pops a reply or answer in here, just a note that I moved your post to the Paint and Body Shop as the best place to have this conversation.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | Just happen to have those bolts sitting on my workbench. The shackle to frame bolts are 3/8 coarse thread x 1" long. Two per side with nuts and lockwashers. The same bolts between shackle and cab, but they screw into a nut plate that goes inside the cab. Lockwashers go under the bolt head. If you don't have the nut plate, you'll need to fabricate something, or use nuts and thick washers, as the nut plate reinforces the cab floor. Shown on Section 1, sheet 3.12 of the FAM. Unfortunately the bolt PN's don't show up correctly in the parts catalog to tell you the sizes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | | | |
