0 members (), 73 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
#1520184 10/03/2023 2:45 PM
Need some info what bolts are used to attach rear mounts to cab and frame.
flattop49,
Before anybody pops a reply or answer in here, just a note that I moved your post to the Paint and Body Shop as the best place to have this conversation. wink
Dan
~ Dan
1951 Chevy 3 window 3100
Just happen to have those bolts sitting on my workbench. The shackle to frame bolts are 3/8 coarse thread x 1" long. Two per side with nuts and lockwashers. The same bolts between shackle and cab, but they screw into a nut plate that goes inside the cab. Lockwashers go under the bolt head. If you don't have the nut plate, you'll need to fabricate something, or use nuts and thick washers, as the nut plate reinforces the cab floor. Shown on Section 1, sheet 3.12 of the FAM. Unfortunately the bolt PN's don't show up correctly in the parts catalog to tell you the sizes.
