0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1519645 09/29/2023 6:47 PM
I have an 18" scratch on my fender that doesn't look quite as bad as the attached photo. I'm wondering if I can rub it out with some compound without dulling my paint. If so, any suggestions? It's several coats of urethane without clearcoat. Thanks
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
That should polish out unless it's down to the primer. Use a mild polishing compound, and the gloss should still be good. Start real easy to see how it goes. I polished out a scratch in some clearcoat, but don't recall what compound I used (it was borrowed along with the polisher.)
Can you feel it with your fingernail? It looks more like a scuff from some non-metallic object like plastic or wood.
1950 Chevrolet 3100 (Ol' Roy)
Try Meguiars Scratch X. For surface scratches and scuffs, it's amazing. Just rub the scratch and its immediate area, no need for more.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
