4 members (MickeyP, KEVINSKI, jay d, Otto Skorzeny), 153 guests, and 2 robots.
Topics128,034
Posts1,055,552
#1518493 09/21/2023 1:10 PM
Picked this up at auction. Just wondering if anyone is using these or is it scrap?
Justice #1518495 09/21/2023 1:29 PM
Moderator, Electrical Bay
Well, they're durable, they only shift once, they aren't exactly light and they are not cheap to have rebuilt. But I hear bracket racers like them, so I wouldn't say it was scrap. I had one for a while in the 60s. It was okay...just needed another couple of gears.
~ Jon
Justice #1518650 09/22/2023 4:08 PM
That is an early one, cast iron, torque tube application, likely 50-54 car. There may be some interest in it for someone
restoring an original car. Racers use the later aluminum case version.
Fred
Justice #1518721 09/23/2023 12:06 AM
"that is not the droid you are looking for." smile
Justice #1519591 09/29/2023 8:00 AM
I rebuilt many of those when I was a high schooler. They are made way better than anything is now.
Won't find any corrugated tin cans for clutch drums in them.
Justice #1519618 09/29/2023 2:59 PM
Be aware that the adapter ring between the trans and the engine block is factory indexed to the crankshaft centerline. If you swap it to a different engine, it takes a special crankshaft adapter fixture and a dial indicator, plus some offset dowel pins, to assure that the torque converter runs concentric with the crankshaft. It's not as critical as the alignment of the torus on a Hydramatic, but it's still a good idea to check the runout.
