Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 68 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#151944 04/09/2007 1:38 AM
1 Offline
I picked up my wrecker boom sat. It was on a f#^& ,It is a model 515 what rpm pto am i looking for. I have the original 216 with a 4 speed. :hammering: Thanks
restoring a 1946 coe wrecker.
#151945 04/09/2007 4:23 AM
I am not an expert, but I doubt you have many choices on pto speeds for your old 4 speed.
Probably have to use what you can find, I suspect it used a regular one like a dump bed.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#151946 04/09/2007 4:48 AM
Got any pictures of the 515 Holmes. One of my old Wreckers had a Chelsea 2 speed PTO. I think it was a model 41. Looked at it not long ago. Most of them are the single speed Brown-Lipe PTO's. What does the Ford have on it.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#151947 04/09/2007 10:48 PM
My 53 has a single speed Chelsa PTO.The Holmes 20,000 lb.wheel lift/underlift uses an 12 volt hydro pump.I will try to get a number off the PTO.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#151948 04/09/2007 11:14 PM
1916 signal,I just sent my man Lefty to look under the wrecker and it says "Chelesa Model 460A" cast into the PTO housing.Hope this helps.
Wanted Good Woman:
#151949 04/10/2007 1:00 AM
1 Offline
I will follow up with parts people using the 460a leed.Thanks gtow69. Spankey the ford has a square hole in the side of trans and a torch cut pto shaft ,no clues there.I am pretty familiar with newer pto's and just wanted to get output speed in the right range. Maybe there wasn't that many choices on output speed? THANKS :hammering:
#151950 04/10/2007 8:28 PM
depending on the winch, it might require a forward and reverse pto... as for speed they are pretty standard unless you do get a two speed, that usually has two speeds one direction, and one speed the other direction, these were used on alot of winches too....it all depends on the winch type.
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
