| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | I picked up my wrecker boom sat. It was on a f#^& ,It is a model 515 what rpm pto am i looking for. I have the original 216 with a 4 speed. :hammering: Thanks
restoring a 1946 coe wrecker.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I am not an expert, but I doubt you have many choices on pto speeds for your old 4 speed. Probably have to use what you can find, I suspect it used a regular one like a dump bed.
Grigg | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Got any pictures of the 515 Holmes. One of my old Wreckers had a Chelsea 2 speed PTO. I think it was a model 41. Looked at it not long ago. Most of them are the single speed Brown-Lipe PTO's. What does the Ford have on it. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | My 53 has a single speed Chelsa PTO.The Holmes 20,000 lb.wheel lift/underlift uses an 12 volt hydro pump.I will try to get a number off the PTO.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | 1916 signal,I just sent my man Lefty to look under the wrecker and it says "Chelesa Model 460A" cast into the PTO housing.Hope this helps.
| | | | | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | I will follow up with parts people using the 460a leed.Thanks gtow69. Spankey the ford has a square hole in the side of trans and a torch cut pto shaft ,no clues there.I am pretty familiar with newer pto's and just wanted to get output speed in the right range. Maybe there wasn't that many choices on output speed? THANKS :hammering:
| | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | depending on the winch, it might require a forward and reverse pto... as for speed they are pretty standard unless you do get a two speed, that usually has two speeds one direction, and one speed the other direction, these were used on alot of winches too....it all depends on the winch type.
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
