0 members (), 116 guests, and 0 robots.
Topics128,127
Posts1,056,679
Members48,452
I have a 1949 3100 with original 18" steering wheel.
I am a little big in the mid section.
Has anyone purchased a 15"steering wheel that looks original?
[email protected]
dougs,
There are a few vendors that are offering a so-called reproduction "reduced diameter" (15") steering wheel that looks like the original design.
Here is just one example I found 15" diameter Reproduction 1947-54 Steering Wheel.
It should be noted that every vendors ad offering this 15" steering wheel indicates that it "Works with 1969-1994 GM tilt columns or aftermarket style tilt columns". This particular vendor even states "Does not fit factory 1947-54 Steering column.".
Look seems right, but I would be concerned about actually fitting your existing steering column (no idea what you have), plus I'm wondering how much harder your steering effort is going to be with the smaller diameter wheel.
Of course, if your truck has been modified with a later steering column to add power steering, that wouldn't really be a problem.
Perhaps someone else has made an attempt to installing one of these wheels and can provide some direct feedback??? headscratch
Dan
~ Dan
1951 Chevy 3 window 3100
Unless you have power steering added to your truck, don't put a smaller wheel on it. The wheels are large for a reason. That's why school buses and semis had 20+ inch steering wheels. You need all the leverage you can get when the truck is at a standstill.
1950 Chevrolet 3100 (Ol' Roy)
dougs,
Just a note here that your post really better belongs in the Interiors forum as the topic is more about your comfort needs inside the cab, so it's been moved there for further discussion and conversation.
It may get moved again to the Driveline forum if the "Interiors Forum" Mods feel it better belongs under the "steering" category. Up to them on that decision though.
Dan wave
~ Dan
Moderated by  ndkid275, Phak1
