1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | I’m in the process of installing a frame mounted Power Brake Booster/MC assembly in my ‘52 3100 and the instructions on CPP website say to install a loop in the vacuum line coming from the manifold due to the booster being below the manifold. It doesn’t specify if the loop goed up above the manifold or down. Another search on the internet showed that a charcoal filter is recommended so gas fumes don’t deteriorate the rubber in the booster. I suppose the filter takes the place of the loop. Can any you you ‘bolters give me any insight and resolutions to the issue?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Aug 2011 Posts: 229 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 229 | This info is interesting as my instructions never mentioned the loop or charcoal canister. Maybe this is new technology! My conversion was several years ago. | | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 | All I have is a check valve on the booster.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | C3 Corvettes had a filter on the vacuum line that went to to headlight actuators, but I have never seen one on the brake booster.
Maybe call and ask them? | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | The info was not in the instructions I received with the kit but from a QR code on a card that came with the kit for more installation instructions. I’ve included a link in my first post.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | Some comparison from a big bolt: The Hydrovac booster is mounted on the frame below the level of the engine, mine is under the driver's side step. The vacuum line starts at the intake manifold and goes up to a combination inverted trap and check valve, it then heads down the firewall and along the frame to the booster. The theory for the loop/trap is to prevent gasoline vapor from condensing and running into the booster.
| | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | I put front disc brakes on my AD years ago and engineered it to use a firewall mounted MC/vacuum/power booster. Initially I did supply vacuum to it but the brakes were wayyyyy too sensitive. I had the thought to try it without the vacuum assist and was somewhat surprised to find that the brakes felt/behaved just fine without vacuum….just takes a little more muscle. I left the booster in place…with no vacuum connection. Been driving it that way for about 10 years. (“Real men” don’t need power brakes….or automatic transmissions….or fuel injection…or air conditioning, or etc etc….I’m joking….) Phak1, try it without the vacuum? Regards, Dave | | | | | Joined: Feb 2019 Posts: 4,507 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,507 | I understand the theory about the gas trap. What doesn’t make sense to me is the booster has a check valve which holds vacuum in the booster until the vacuum drops below minimum then open to increase the vacuum in the booster. If the valve is shut closed, how would gas fumes reach the booster. What makes any sense to me, is it’s there as a failsafe if the check valve fails. The vacuum line starts at the intake manifold and goes up to a combination inverted trap and check valve, it then heads down the firewall and along the frame to the booster. By invert loop, do you mean like an inverted ‘U’?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | Yes, inverted trap is like an upside down "U" or "P". In my application, the rubber vacuum hose runs from the base of the carburetor up to some 1/2" steel tubing, the tube is vertical and connects to the bottom of the check valve, then out of the top of the valve it makes a short vertical run and then a 180 degree turn and down to the frame.
