4 members (Gdads51, dt235sd, baldeagle, Mike Roache), 171 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1518804 09/23/2023 4:06 PM
So i got the parts home and am looking at the trans. The front shaft looks like it is missing the piece that covers the input shafy that the throwout bearing rides on . Found a parts pic and it shows a seperate piece from the front bearing cover. Could this be broke/missing. cant post a pic at this time. will try later thanks
Riding in the Passing Lane
That trans. is notorious for breaking the tube off the front brg. retainer. If the collar is still on against the front brg. with 4 bolts, then the tube is broken off. If the complete assembly is gone then someone has taken it off for another truck.
I don't think it available new but you might check with Novak trans parts.
George
1972 Chevy c10 Cheyenne Super
Novak does have it, + if you want the Clint Eastwood special ("for a few dollars more") you can upgrade to a positive seal if yours doesn't have one.
Noval SM-420 parts
I updated mine and Novak did a beautiful job and quick shipping also.
Noval SM-420 parts
Bill is B-3761982-K Kit, retainer, front input bearing, SM420 transmission, billet, GM style
the one with a seal? May just call them tomorrow and check on that.
EDIT: disregard, scrolled down the page and found the info for the seal. Thanks for the info though. Didn't know they could do that.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Plus the material they use for the new part isn't near as fragile as the stock part.
