0 members (), 85 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
#1519099 09/25/2023 8:23 PM
I am in the process of changing my cab from a 3 window (1953 3600) to a 5 window (1952 3100) and have encountered a puzzling hitch. I took the after marked electric wiper system out of the 1953 and when going to install in the 1952 the length of the wiper connecting rods to the wiper motor is about 6" short of matching the holes in the 1952 cab. Anyone know if the spacing of the wiper holes in the cabs changed?
I doubt that the wiper spacing (where the arms go on the cowl) would have changed from 47-53. Maybe in 54 with the single piece windshield would be different, but you'd have to get measurements from each to be sure. I could measure my '51 cab if that would help.
I don't know if someone filled in the original holes and cut new holes in the 1953 cab, as I no longer have that cab, and modified the arm length (they do look like they have been cut and welded back together) but they definitely aren't long enough to go from one side to the motor and to the other side. Doesn't make any sense that they would do this as it would be a lot of work for basically nothing! I guess I could cut the arms and add a length to each side so that they reach the motor. I would think that if I made sure both wipers were in the "parked" position when I did this it would all work out fine. Thoughts? The other option would be to look for some stock arms that are the right length.
Patharr,
Just a note that I think your conversation may be better answered through more conversation in the Paint and Body Shop.
I have moved it there to help the conversation along. wink
Dan
~ Dan
1951 Chevy 3 window 3100
I have the stock arms handy if you need measurements on those. Not installed yet. Agree with Dan that this should have been in Paint and Body. Should have mentioned that as it's "my" forum. blush
If you could supply the lengths for the stock arms, center to center of the holes for each side, I would greatly appreciate it.
Right side is 25-7/8" from arm pivot to motor connection hole
Left side is 7-5/8" from arm pivot to motor connection hole
Both have doglegs in them probably for clearance to other stuff under the dash. Here's a picture.
Thanks for the measurements and photo. I am currently installing the electric motor and will modify the arm lengths to fit after i put the motor in. Hopefully the motor is in the "parked" position and when I modify the arms everything will work out OK.
