6 members (Southerntruck, dt235sd, Gdads51, GMCJammer51, NJC, John L.), 113 guests, and 3 robots.
Topics128,091
Posts1,056,392
Members48,442
#1518372 09/20/2023 6:50 PM
Spare off something.
Axle from like vehicle. Bolt axle backwards through wheel.
Weld axle gear to plate for grinder. Place grinder on stand with axle gear.
I did this so if I'm working at home the grinder is outside. I can just lift it of and carry in the garage. Also have a vise with same gear welded to it. Can just change them out. Vise is just used for sharpening blades mostly. Not very good for to much torque.
Nice job. thumbs_up
A guy just need to scrounge up the parts from a wrecking yard. Good use for that temporary spare tire. It's not really good for use as a spare, anyway. wink
Looking good! I do something similar, but I use a discarded 18 wheeler brake drum- - - - -which weighs about 100 pounds, and anchors whatever implement I mount on it very effectively, but it can be tilted and rolled anyhere in the shop it's needed at the moment. A piece of 4" schedule 40 pipe and a steel plate on top completes the assembly.
Hopefully a de-pressurized spare as you might be constantly shooting sparks and grinding cast off in its general direction.
De-pressurized heck no we die like men.
That's also the only good use I can think of for a Firestone RH5 truck wheel!
Got that right hotrod
Thr RH5 also makes a good camping firepit.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
I'm soon going to have five RH-5 fire pits available to any 'Bolter who wants one. And yes Jerry, I'll sabotage it so no attempt could ever be made to use it as a wheel. :-)
Tronman,
You can offer those up in the Swap Meet "Freebies" forum. wink
~ Dan
1951 Chevy 3 window 3100
Crusty Old Sarge
Crusty Old Sarge
I recently had a grinder/sander stand given to me. The stand was built by my Wife's Uncle years ago. The stand is pretty heavy made from a Big Truck brake drum as Jerry has described. Her uncle passed away last year and his Commercial Diesel shop is being sold. I was glad to keep this stand in the family.
Grinder Stand
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Moderated by  MNSmith
