0 members (), 144 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
So i got a clutch kit from my FLAP. Put it in ( with the clutch plate properly oriented) as well as the transmission. I tightened it cross-wise so equal pressure. Linkage was hooked up but clutch wouldn’t work. Took trans, pressure plate and clutch disk out. Double checked the disk- it was oriented correctly. Looked more closely at the pressure plate. Seems that the “fingers” are higher than the original one. Also, the clutch disk had 5 springs instead of 6 on the original. Could this be a car pressure plate/clutch setup? If so, would this explain why it does not work.
When you say it wouldn't work, did it not release or did it not engage?
It may be a throwout bearing issue. Did one come with the kit?
Have you checked the adjustment of the pedal linkage and the clutch fork?
IIt wouldn’t release. t came with a short throw out bearing that the clutch fork wouldn’t fit into the groove (too large of a diameter). Checked the pedal linkage adjustment.
Insomniac
Insomniac
After I bought the wrong clutch kit, I called Perfection Clutch's tech support line. The rep told me that there were 2 different throw out bearings. In order to get the correct kit, I needed to measure the bearing.
If you got the wrong bearing in your kit, you can buy the bearing separately.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Riding in the Passing Lane
If it has the fingers that extend up out of the pressure plate cover, it should use the short TO brg. I have never seen one that the fork would not fit in. I can't help there.
It doesn't matter if the disc has a different amount of springs. I believe the car & light truck use the same clutch.
George
1972 Chevy c10 Cheyenne Super
