1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
Does anyone know the size threads / bolt I need to pull this?
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
Borrow a harmonic balancer puller from your local auto parts store. It'll have an assortment of bolts in the kit to do the job. O'Reilly, Advance and Auto Zone have these for free loan.
1950 Chevrolet 3100 (Ol' Roy)
Riding in the Passing Lane
They use 3/8 in. fine threads (SAE).
George
1972 Chevy c10 Cheyenne Super
WHAT!!!? You don't have a collection of bolts of various sizes that you could fit in there to check? What kind of a Stovebolter are you anyway? wink
If it's a 216, then it would be 3/8 coarse thread. But a 216 only has two threaded holes and lugs for a hand crank, so that's not it. But if the engine is similar vintage, it's probably the same thread size.
What Otto said. They just charge you a deposit, refunded when you return it.
Do you own a tap and die set? You can check size with that.
1949 gmc 1-ton
Kevin,
The engine he is working on is a later 250 I-6 and I am pretty sure George (Wrenchbender Ret.) hit the nail on the head for needed bolt size and thread. wink
Dan
~ Dan
1951 Chevy 3 window 3100
Yes it’s a 3/8 th fine thread. I picked up the puller from Advanced but, the bolt was 4 inch & only had 2 in the set.
So tomorrow I’m heading to the Hdw store and buy 3 two inch length ones. Should h get R off!
😎I do have bunches of nuts & bolts around but not what I needed this time!
Thanks!
Word of caution: when installing puller bolts to damper be sure they are short enough not to make contact with the timing cover, it's easy to ruin a timing cover.
BC
1960 C60 pasture art
H Online: Content
The 194/230/250/292 series engines use 3/8-24 threads on the balancer. Do yourself a big favor and chase the crud out of the threads with a tap before attempting to thread bolts into them.
