4 members (Hotrod Lincoln, walter74, J Lucas, 3800GUY), 138 guests, and 2 robots.
Topics128,134
Posts1,056,406
Members48,441
Hi. I have a 1956 with original steering box which looks to have a bit of slack in it. I've seen some screws on the side and bottom of the box which I assume are for adjustment? Which is the best way to adjust and take up some slack.
Cheers
Do you have a factory service manual for your truck? The procedure is outlined in the steering section under "minor service operations".
1950 Chevrolet 3100 (Ol' Roy)
This was covered in this thread 10 days ago.
Here's a shop manual.
eBay Link
Stooby,
I see you are located across the pond and may not have easy access to a "Shop Manual".
If you need the shop manual info sooner, and don't mind viewing/reading on your computer, this is a freely accessible web link to the the 1955 2nd Series Shop Manual that covers your 1956 steering box checks and adjustments (and everything else on your truck).
For the direct link to the section you need, click HERE.
Once you have given this a read, come back and ask more questions if you need more info. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
