1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
AD Addict & Tinkerer
We have an update to an old Tech Tip on "How to Measure Cylinder Taper" by Jerry "Hotrod Lincoln" Herbison that was originally posted July 2017.
You’ve disassembled the engine and the pistons are out ... You were careful in doing that, right? If there were some ridges at the top, the only correct way to remove a ring ridge is with a reamer designed specifically for that purpose -- Do that BEFORE you attempt to remove the piston so you don’t break a piston ring land by pounding them out.
Read it HERE in the Engines Tech Tips sub-form.
If you have any questions or comments about this Tech Tip, please feel free to post in the ENGINE SHOP forum.
Phil
Project Journals
Stovebolt Gallery Forum
That was an error by an editor (not my original words) which I pointed out at the time. "Sanding" the ridge away isn't possible. It was supposed to be deleted, as the only correct way to remove a ring ridge is with a reamer designed specifically for that purpose. Please trash it! I was not aware that it was still stinking up the tech tip!
https://www.ebay.com/itm/234447574904?
24601
24601
On it, Jerry -- Thanks for the correction!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
24601
24601
Done!
We regret the error.
"The only people who should use the possessive 'we' are kings, newspaper editors, and persons with tapeworms."
-- Mark Twain
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Domo Arigato Gaziamas!
