We have an update to an old Tech Tip on "How to Measure Cylinder Taper" by Jerry "Hotrod Lincoln" Herbison that was originally posted July 2017.
You’ve disassembled the engine and the pistons are out ... You were careful in doing that, right? If there were some ridges at the top, the only correct way to remove a ring ridge is with a reamer designed specifically for that purpose -- Do that BEFORE you attempt to remove the piston so you don’t break a piston ring land by pounding them out.
Read more (or print out - an easy two-pager) in the PDF. If you have any questions or comments about this Tech Tip, please feel free to post HERE in the Engine Shop Forum.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
