1 members (TUTS 59), 95 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
#1517128 09/13/2023 12:05 PM
I’m on my second gasket that doesn’t fit but apparently is correct for year/model.
Any help appreciated
1955 2nd series 3800
1955 Chevrolet 3800 2nd Series
I recently rebuilt my rear differential and did not use a gasket to replace the cover. I just used a thin bead of Permatex Black Gasket maker/silicone. No problems with leaks.
Dave from Northern Kentucky
My 54 3100
Good morning Rust! Your rear differential looks like an Eaton HO52 to me. The rear cover gasket you need is a FELPRO RDS5088 Gasket . You can look them up online. Just search FELPRO RDS5088. This is the gasket I purchased and installed on my 1954 3604 which has the Eaton HO52 Rear differential. Here's a photo of mine...
View of 1954 3600 Rear Differential
Ron - - Dusty53
1954 Chevy 3604
Sure does look right, though yours looks a whole lot nicer than mine right now!
Thanks!
Going to pick this up while I wait for the gasket. Going to have to change this oil a few times, looks like it hasn’t been changed in many many years. Going to flush out the old sludge.
You should be able to flush it out . I drained the rear diff oil by loosening up the rear cover bolts enough to allow it to drain, retightened the bolts, filled it up with diesel fuel, raised the rear end off the ground and let it operate in 1st gear for a few minutes , loosened the rear cover to drain the diesel, removed the rear cover, checked for any obvious issues, replaced the cover/gasket, refilled with 80-90 Gear Oil, and went on down the road.
Note that mine leaked at the front seal, so I went through the process of replacing the front seal while I was working on the rear diff......now that front retainer gasket may be a bit harder to find. PM me if you decide to go down that road and I'll share what the experts shared with me.
Best wishes on your project.
Ron - - Dusty53
1954 Chevy 3604
7
7 Offline
I made all the gaskets for the rear axle, that includes the axle shaft hub covers, front pig, rear cover, and front pinion bearing retainer gaskets. I used a heavy FelPro material for the front and rear and a lighter McCord paper for the hub and pinion. A little Permatex #2 and all is well.
Rustbucket Ranch
Rustbucket Ranch
Looks like a HO72 rear end, which would be correct for the 3800. I used Fel-pro RDS5090 carrier gasket and Fel-pro RDS5088 cover gasket when I went through the one on my '58.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
So I filled it while waiting and leaked in same spot you described.
