9 members (chevy51truck, Gdads51, Woodcmiami, KEVINSKI, Peggy M, Wickedbass, Tinker5, Hotrod Lincoln, 1 invisible), 101 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#1517207 09/13/2023 6:52 PM
I have never owned a torque wrench and will be buying one to reinstall my cylinder head. What do folks find works better? The new digital wrenches or the old analog with the pointer? Or is there no difference, just personal preference.
Thanks!
Daves46pu #1517216 09/13/2023 7:59 PM
I have both the clicker type and beam type with pointer. The clicker is pretty dummy-proof as you don't have to look at the pointer (sometimes hard to do.) You do have to be able to hear the click, though. wink
Daves46pu #1517226 09/13/2023 8:57 PM
Moderator, Electrical Bay
I am a 60 year fan of the pointer type. As a friend of mine learned, if the batteries go out or go low in the digital ones, a strong guy can snap a head bolt waiting for the thing to beep or flash or whatever it is they do. And then you get to learn how to extract a bolt which broke off just inside the threaded zone...a bolt that was really tight when it snapped.
~ Jon
Daves46pu #1517227 09/13/2023 8:58 PM
Thanks for the info!
Daves46pu #1517239 09/13/2023 9:54 PM
No batteries in my clicker torque wrench, just some sort of mechanism that snaps over center when the torque value is reached.
Daves46pu #1517289 09/14/2023 1:38 AM
62401
Also a fan of the clicker type. Here's the one I got to do my 261 rebuild. I'm very pleased with it. As Jerry (Hotrod Lincoln) taught me, there is a way to hold it so you do not stress your shoulder. And you will want to calibrate it. Calibration is good to do whether you have a clicker or a needle.
Jerry (Hotrod Lincoln) using my torque wrench on my 261 rebuild
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Daves46pu #1517319 09/14/2023 4:21 AM
We have both clickers and beepers BUT we have the old beam to calibrate both. Two half inch drive sockets welded together connect the beam to the others.
Evan
Moderated by  MNSmith
